I have a stock bottom end BNR32.
The prior owner installed unknown HKS cams (not the v-cam set up).
HKS turbos/intercooler piping (i have to look a the turbines again to see which exact ones).
Full exhaust.
Running on an AEM V2 with MAF deletes.
I'm going to get it retuned, add flex fuel to be able to run e85, it has no power below 4K, and I'm going to shoot for a more linear power band without swapping the turbos/cams while turning up the power.
Also, does not run well at higher elevations, so that will be addressed as well.
I think I'll be able to hit 500-550 hp safely if I upgrade some fuel components.
The working plan is to add 1100 ID injectors, walbro 400 lph pump (e85 compatible), and a nismo fuel pressure regulator.
Can anyone chime in here and give me some feedback on my goals and my shopping list?
Thanks in advance!
Full exhaust.
Thanks in advance!
