Hey does anyone know if the ati super damper still uses the OEM timing mark location, or do you have to make your own... I fired up my car today and we cranked the CAS all the way to the left, but according to the timing mark on the engine I'm still at 15degrees advance, shouldn't I be at 0 degrees or retarded?
I have aftermarket cams, tomei type A. I'm wondering if this affected it, other than that the car runs like ****. yay.
well angle, a term used in automotive context, indicating the degrees of rotation of the distributor cam during which the ignition contact breaker points in the distributor are closed.
