so i need to know what color the wires are, and what position in the plug on both MAFs on the rb26, on mine they have been cut and extended (previous owner) i have the wires out of the loom all the way back to where they are cut/spliced and i want to make sure they re-connected them to the right wire on the MAF.
Also the factory wiring harness wires are different colors than the little bit of OEM wiring that comes from the MAFs
Sorry if i make it hard to understand, i find it hard to explan
in the lower picture you can see i have a green with black stripe, and white with red stripe and a black and a white wire, but on my MAF plug in the upper picture i have black with a white stripe and a orange wire as well as a black and white wire
so you can tell something isn't right, i need to know which end has the wrong colors, so any of you guys that have stock air boxes or know that your MAF harness hasn't been hacked, could you look and see what colors the wires are and in what order they go
AGAIN sorry if its hard to understand, i tried to explain it the best i can
this is all in attempts to find out my wacky engine troubles i have
PS all of the connections that were made, actually were done well, its all soldered and was heat shrunk
