Hello , new to Skylines. I have found a 1990 GTR RB26DETT , but it appears that there are 2 cylinders that are low compression. Spoke with the mechanic that inspected it and suggests a rebuild. The seller is offering to give another motor with a solid bottom end and the original motor has a solid top end. Basically from what I understand it would be a 2 make one motor. I would like to use it as a project / learning car but seeking some advice / wisdom on whether or not it would be worth while to do. The rest of the car is in very good shape.
Car runs but throws nasty smoke. Turbos are making boost.
Or should I check the for sale page and get one that is good to go then worry about fixing later.
Thank you in advance for your time.
