R32 GTR 52,000 miles, stock motor.
new timing belt and water pump 5,000 miles ago.
The engine is making a very odd sound from the head, right under the oil cap.
Sounds exactly like a squeaking belt. ( humming/squeak, on and off only at warm idle)
its not loud, a bit quieter then the injector ticking. if throttle is increased ANY bit the sounds goes away.
used a stethoscope and its 100% being generated from the head directly under the oil cap.
before i pull the valve cover off and lift that cam cap any ideas? or recommendations?
