I've seen alot of set up aboutI engine/turbo but rarely seen anyone talks about their suspension set up. I am hoping to start a thread about this topic to aid whoever is needed.
here is the format:
Purpose of the car:
Suspension -
Spring Rate -
Control Arms Front -
Control Arms Rear -
Bushings -
Alighment -
Chassis Reinforment -
Brakes -
Notes:
__________________________________________________ _________
This is my Set up.
Purpose of the car: Mostly drifting/ occasional track day. Daily weekend driven.
Suspension - Aragosta Fully adjustable Std Coilover.
Spring Rate - Std 7.7kg/mm 5.5kg/mm, Midori 10kg/mm, 9kg/mm for track.
Control Arms Front - Feast SPL Front upper control arms
- Nismo Lower Control Arms
- SPL Front Tension rod
- SPL V5 tie rod ends
Control Arms Rear - SPL Upper Control Amrs
- SPL Traction rod
- SPL Tie rod
Bushings - Nismo bushings in lower arms
- Nismo rear coilover mount bushing
- Custom Spherical Bearings on rear knuckle
- SPL solid subframe bushing
Alighment - I haven't done alighment yet.
Chassis Reinforment - Tomei 3pt front strut bat
- 14pt Rollcage with X door bars (not yet)
Brakes - Brembo 6pot front Monoblock.
- 355mm 2pcs rotor
- Brembo R33 rear single piston
- 350mm V36 rotor
Notes:
I am running front GTS-t suspension assembly, RWD conversion.
S13 no hicas rear subframe with GTR knuckle/upright.
here is the format:
Purpose of the car:
Suspension -
Spring Rate -
Control Arms Rear -
Bushings -
Alighment -
Brakes -
Notes:
This is my Set up.
- SPL Traction rod
- SPL Tie rod
- 355mm 2pcs rotor
- 350mm V36 rotor
Notes:
