Hey guys do you have any idea of how to unscrew that F***** screw that holds the crank pulley...I have tried to unscrew it with a impact gun but no results...is it clockwise or counter clockwise threaded?? i need your help since i am in a rebuilt process
Crank pulley
mine was a complete nightmare, it involved me and a friend hanging off the end of a 6ft snype, and that was still moving the car in 5th gear with the park brake on so my dad stood on the brakes at the same time. i though i was going to break my crank. you could always try to borrow a bigger (3/4" or 1") impact if the engine is out.
try a air powered torque gun
A dead blow hammer and the right size socket can take it out without needing to lock the engine in place. I did it easily3-5 good whacks and voila. You're inpact gun is underpowered or your compressor is not flowing enough CFM...
the balancer has rubber on it, i took mine off with an electric impact gun from ct 250lbs tq max, just hold the gun on there even if it takes 10 minutes, eventually it will loosen.Proud owner of the 2nd Skyline and the only GTR on the island!
do you have a heavy dead blow hammer?Black 1991 GTR. Serious garage stand mantle/parts car.
I'm with NismoS-tune on this one, give the bolt a good few whacks with a hammer, use a big deadblow or get a big punch and hit it with a 2lb hammer. The problem is the threads of the bolt have siezed - hitting it with a hammer should free up the threads. I do this often to free up jammed bolts and it usually works.
