Not sure what to upgrade next?
  • Not sure what to upgrade next?
    So far i have upgraded:
    clutch
    pressure plate
    flywheel
    intake
    downpipe
    exhaust
    injectors (850cc)
    nistune board (whenever ztune gets the damn thing slowest service ever)
    boost controller and turbo timer
    I am thinking i mide aswell get a testpipe but then not sure what i should do after that.
    Possibly fuel pump and turbos?
    My rear suspension has some play so i will attend to that first anyone know a good place to get all the bushings?
    Nathyne
    1994 GTR - 6 Years with this car... damn time flies.
    1998 Subaru V4 STI - Daily/winter beast
    nissan has bushings. As for next upgrade, get suspension the big single turbo. Of course, every time you install a performance part, you should be tuning unless the parts all go on at once.
      Ohh yes forgot i have some HKS coil overs, Perhaps some adjustable control arms next then?
      Once i get my ECU back i will be taking her in for a tune aswell
      Also did change all my fluids (except diffs as soon as i pick up the oil i'll do that) aswell so that is not a concern.
        Basic boost up on R32GTR with stock turbo's, stock engine to 430hp at engine on high boost setting (if stock turbo's, stock engine are in good condition. Or aim for lower hp level like 350-390hp if you suspect turbo's, engine, etc are not 100%) -
        Retunable ECU
        Boost controller
        Twin plate clutch
        600cc injectors (or bigger if your aiming for more hp later on)
        255-300lph fuelpump (depends on size of injectors and from Nismo, Bosch, etc)
        Z32 AFM x2 + plugs / tails (Tomei, etc sell the plugs / tails)
        Podfilters x 2 (usually bought with a intake kit)
        Full exhaust from turbo's
        PFR7A sparkplugs
        Also do a compression test on engine before doing any mods.
          Have you done any upgrades on brakes ? suspension tuning ?
          making it faster is half the job , making it stop again is just as important
          As Skym said , i would be doing a compression test before expecting the poor old girl to make more power .. just my opinion though , i have never been one to bolt on upgrades until she blows kinda thing !
            Compression test doesn't tell you about any loosening rod bolts or worn bearings.
              I have done front brake pads and put on ss brake lines all the way around i was thinking of geting some rotors that are not drilled and upgrading my rears aswell.
              Okay i will do a compression test then before i get a boost controller or drill out the boost restrictor.
              Okay so i will:
              get replacement bushing from nissan
              replace rear brake pads (fronts are brand new still)
              replace spark plugs (forgot about these oops! should i maybe do coil packs aswell?)
              walbro fuel pump
              Do you think that sounds about right?
              Nathyne
                I'll assume the rod bolts in the rb26dett are the same setup in any other motor i've built , when they are tightened they are designed to stretch slightly and as a general rule of thumb they don't work themselves loose unless they have been removed and reused. Badley worn bottom end usually manifests itself as a low knocking sound if very bad or a drop in oil preassure as the increased gap on the mains , big ends etc lets oil escape the journals too fast.
                Compression test lets you know the condition of the valve seats , rings , head gasket etc etc. No point increasing boost if the combustion chambers cant hold it.
                On a side note , a failing bottom end will sometimes be detected by the knock sensor and the ECU will retard timing to try and reduce it making the engine bog a bit under acceleration. If you have a device to plug into the ECU ( i used to use a palm zire 71 with some software from www.digitaltuning.com to read the engines vital signs ) you can check the knocksum for this.
