as the title says
looking for a DIY on removing the PCM valve
You sure are looking for many DYIs! Most of us just start chopping away. Talk to someone who know's mechanical/automotive about this stuff and they should be able to help you understand what's to keep and what's to chuck.Black 1991 GTR. Serious garage stand mantle/parts car.
I assume you mean PCV valve? (Positive Crankcase Ventalation Valve)
You're doing this to keep from blowing crank case vapours into the turbos/exhaust?
I saw someting on here about doing that and I THINK they just blocked it off and ran the breathers to the catch tank.
The only thing I don't like about that is excess crank case pressure blowing out seals and such. I'm not sure if the cam cover breathers will vent quickly enough.
Do some looking to verify though.
The stock boost controller is the PCM valve . Like NismoS-tune said don't look for DIY guides, just do it yourself. Follow the vaccum lines and it will all make sense. Just unbolt the solenoid and throw it on the ground!!! Then follow the lines and get rid of everything you dont need (I said the same thing in Cobraa's thread a few threads before this one).
