drain the old fuel?
  • drain the old fuel?
    hey is there a dain plug on the gas tanks on the gtrs? if not whats the best wway of gettin the old fuel out of my tank?
    Disconnect the fuel line at the bottom of your fuel filter. (This is easier with two people) Turn the key to run position and the fuel will begin to come out of the hose. You may have to keep cycling the key on and off if it stops coming out. Try your best to catch all the fuel with a large bucket or something. You'll have to be creative on how you're going to catch/store all the existing fuel that comes out of the tank.
    That will be your easiest way without dropping the fuel tank and lol no there isn't a drain plug.
    EDIT: You don't have to turn the key to the run position either on or run will suffice. You won't wear the starter/drain the battery as much if you just cycle the key to the ON position though!
    1992 Nissan Skyline GT-R - SOLD
    1995 Subaru Impreza WRX STi Type-RA - Rod knock, then sold
    2005 Subaru Impreza WRX STi
      ohh ok ya ill have to do that thanks
