I just put my gtr on a hoist, and put it in gear to try and troubleshoot some rear end noises i've been having.. I had thought it was maybe the diff, ie- it was dieing, or was a 2 way racing diff that i didn't know about. It turns out that as i blip the throttle the driveshaft is making some clacking noises either in the center joint, or joint nearest the tranny....
This is where your help comes in! : Does this correspond with feeling some rear end vibration/chatter when starting in first, and then some muffled rear end noise that increases with speed after about 40 km/h? I'd desribe the noise as almost being like a wheel bearing or diff starting go bust, ie-sort of a drone/humm. I'm hoping you'll say this is how it is with a driveshaft going bad so my work is limited! ... thanks for the help
