Will 17x8 + 17x9 +35 fit an r32 gtr? im thinking yes but just need confirmation
Wheel offset
Wheel offset
Proud owner of the 2nd Skyline and the only GTR on the island!
Boost@14PSI, YellowJacket Coils, Extreme TSC, Full Nismo N1 Bodykit, Greddy Speed Cut Controller, HKS Turbo Timer, 280LPH Denso Fuel Pump, Nismo Slave Cylinder, AMS BOVs, Nismo Clutch Pivot, ACT Xtreme 6 Puck and HDPP, Greddy Panel FilterTags: None
Doesn't staggering wheel sizes on a GTR do bad things to the HICAS? I'm with Kyles_R32, 17X10 +20 FTW.My Garage:
1990 Nissan Skyline GTR Nismo Edition - Action Hotdog Go!
2008 Audi RS4 - Hand Banana
1998 Subaru Legacy 2.5GT- Dirty Winter Car
1988 Toyota Supra Base - Trojan Judas Hairnet Battle Tree.
I thought hicas would only act up if say the back were 18 and the front were 17, i dont think it cares about width.Also isnt the offset of the stock rims 30?Last edited by MikeRWK; 07-22-2010, 08:24 AM.Proud owner of the 2nd Skyline and the only GTR on the island!
Im not staggering, prolly going with 205/50 to keep the speedometer almost dead on, bobbo u got ne pics? i bought some bbs lm golds and am now wondering if i should get spacersProud owner of the 2nd Skyline and the only GTR on the island!
so with 15mm spacers i would be at 20mm offset right?Proud owner of the 2nd Skyline and the only GTR on the island!
10's can be done easily with the proper choice of tire and wheel sizeOriginally posted by Marus92 View PostHow the hell can 17x10 be done?
Most threads I have seen online seem to show that more than 9.5" wide you need to roll fenders on R32s, especially with a low offset.
I'm saving up for 17x9 255R40s.
As far as staggering goes, it's not the wheel specifically or the tire, it is a combination of the 2....
If you can match up the tire and wheel size to produce the same circumfrance when mounted then you are perfectly fine. It's when the rotational diameter of the tire is different where you run into problems not with the hicas but with the attessa system.
running 205/40's on different width wheels will not produce the same rotational size and therefore possibly cause pre-mature wear or throw a code
Anyone know of a calculator?Proud owner of the 2nd Skyline and the only GTR on the island!
