I recently had a MiNE'S 320km/h cluster installed in my GTR and afterwards, I was getting a bunch of warning lights flashing. We compared it to my original cluster and found that the original was missing the bulbs for the 4WD, HICAS and ABS.
After looking under the hood it appears that my ABS had been removed by the previous owner. As for the HICAS and 4WD, I have no idea why they are missing. The mechanic took it for a drive test drive and when he got back he said that the 4WD is definetly working, but I don't know how he could tell.
Anyway, I've been having problems with the MiNE'S cluster to I removed it today and decided to take a look at my fuse/relay boxes inside the car and under the hood.
Inside the car, I am missing fuse #2 and #3 which according to the manual are "electronic parts" and "transmission control". I'm also missing #14, but that apears to be a spare.
Under the hood I am missing the 75A "main" fuse and the "A/T IND" relay as well as the "inhibit" relay. When I look at the empty spaces for those relays, I only see an empty hole. There doesn't appear to be a harness in there. Does that mean that they were never there to begin with or did someone just remove the relay AND harness?
When I install my original cluster, I am going to replace the 4WD and HICAS bulbs and see what happens. Even if they stay on, it will help me troubleshoot what is wrong.
What fuses/relays are you guys missing/have removed. It would help to know what effect these missing fuses and relays are having on my car, if any.
Thanks!
-Kenji
Thanks!
-Kenji
