Ok so the other day I put in a welded divide charge pipe, the one that says Twin Turbo on it. When I took off the old pipe I noticed there was a bit of oil in it. This slightly concerned me. It wasn't a crazy amount but there was enough so that I could rub my fingers in it and It was slightly liquidy (sp?) and there was most definitely residue. Does this mean my turbos are leaking or is this normal?
Secondly, my car used to have a lot of vibration when going over 160 and even more when braking slightly hard. I got new tires put in yesterday and it seemed to correct the over 160 issue but the braking issue is still there. One of my rims is slightly cracked I know so Iam wondering if it is bent as well as this is a good possibility. However, someone else I know suggested that my rotors could be warped. Is there any other possibilities is there a way to test the warped-ness of my rotors?
