Hi guys,
I recently got my car back from Cam at lightspeed after getting the Vipec installed and tuned so havnt been on here for awhile.
Now that I have it back I will continue on with small mods and odds and ends.
My question for you is this : I would like to install my oil filter relocation kit again and was thinking of running a oil cooler. Is the N1 pump strong enough to pump that extra distance with the added resistance or should I just stick to the oil cooler ? Obviously the cooler is far more important then the reloc. kit.
Not sure if I can run 1 or both items with no problems. I have seen ALOT of pictures and threads of guys running the N1 pump on built engines with no problems and they are running both the relocation kit and the oil cooler so maybe if you guys have this set up you can tell me how it works for you.
Thanks guys. Also hope you all had a great summer with your GTR's!
