U-joint bolt and nut stuck??
  • U-joint bolt and nut stuck??
    Trying to remove my tranny and can not loosen the 4 - 17mm bolts at the u-joint, behind the tranny. I have sprayed it and used as much tourque as I can give. Has anyone ever ground the bolts off?? This seems to be my only option. What size and grade are these bolts.
    Thanks for the help.
    1990 Skyline GTS --- SOLD
    1992 Skyline GTR Lawn Ornament
    2004 Toyota Matrix XRS --Grocery getter
    1998 Mazda B2500 -- for sale
    2000 Honda Accord- Fully loaded winter beater
    nothing?? No one has ever had this problem??
      I had to put a long screw driver between the joint and turn the drive shaft until it butted up against the floor.
      Then double wrenched the nut off with a third wrench holding the bolt hex head.
      Helps if you have someone assist.
      GL wit it!
      Favorites
      lucky_cefiro
      you\'re not listening
      entelijint
      stop saying "yall"... i'm picturing you with a mullet.
      mullet+skyline=*shiver* i dont even want to think about it
      Originally posted by specialedition
      He ended up popping a tired and he failed at life.
        Finally got them off. Thanks for the help speedfreak
