ok i have 4wd when the light is off and when it turns on i only get rear tire fire.
ok so i have done all the usual stuff to try to fix my problem. She throws code 21. Throttle sensor or circut. the following is a list of what i have done to fix my problem
beed the system.. done
check error code.. done
replaced sensor.. done
calibrated to .5V ign on and idle.. done
checked that is sweeps from .5 to 4.2 at WOT.. done
checked grounds.. done
I have taken note of when the light comes on and what i did just before it comes on.
The light will come on at random and at anytime. it seems to more commomly come on when...
the car is up to temp
just after i put on the brakes for a light or something
when its damp or wet (raining)
more commonly at night, like 8 out of 10 times it will be at night
other things of note are..
no other lights come on.
when the light comes on its always only error code 21.
it only ever comes on if the car is in motion it seems.
if i turn the car off and on again i will some times lose the light for a few minutes and 4wd will work.
when the light turns on it will not turn off unless i stop the car and motor.
the light has come on every day for the past two weeks that i have been keeping track.
i have all the factory systems intact (4wd abs hicas) nothing has been removed.
abs and hicas work fine.
I am running an aem ems for my year gtr for my ecu
last but not least im currently running 470 whp at 20 psi and two wheel drive is a death trap with only a pair of 245 25 17 to keep me planted.
some one please help me!
ps feel free to call my cell at anytime to ask me for more details or to let me know what you think i might need to do. names dustin 604 786 1272
thanks
thanks
