Hey Everyone,
After a year of being down, I finally turned the key to start her up last week. Built bottom end, refreshed head with type B poncams, Haltech PnP ECU with MAP sensor, etc. Wouldn't run worth crap, but figured out there was an issue with the connection to the MAP sensor, and corrected timing.
Now it runs and idles, but only on 5 cylinders. Checked the coils, Splitfires, all but one had resistance of 1.3-1.5, cylinder 1 had 2.5. Replaced this with the best of my stock coils which read 1.2. Now I'm not sure what the resistance for the Splitfires should be, couldn't find that info. Still no luck.
Check the ignitor as per the manual, voltage at the connector going to the coils was 11.2-11.3 across all 6 wires, higher than the 9.5V the manual says they should be, but nothing out of line.
Checked spark plugs, and they all look the same, carboned up smelling like fuel (need a tune!).
I'm at a loss as to what to check next. Any ideas would be appreciated! Need to get this running so Vex can tune it for me.
Thanks,
Mike
Thanks,
Mike
