Car: '92 GTR
Mods: Intake, exhaust, boost restrictor pulled, suspension and ACT clutch.
Problem: Car randomly stalls at idle & if the problem happens when driving it feels like it's hitting fuel cut while cruising around at part throttle. Problem goes away when I give it some gas.
Attempted solutions:
-Replaced TPS and adjusted new one properly to 0.5V at closed throttle and 4.0V at full throttle. Resistance is also in check at 2.0 kOhms at closed throttle and 10.0 kOhms at full throttle.
-Replaced fuel filter.
-Checked grounds.
Ideas:
-Could it be an O2 sensor problem since the problem goes away under moderate to full throttle?
-MAFS seem fine but have not ruled them out, just seems unlikely that they would be intermittent and work properly with more air going through them...
-No boost / vacuum leaks that I can find and the car runs fine 99% of the time.
Any input is appreciated, I will be checking more stuff tonight and tomorrow as I rack my brain for ideas...
-Checked grounds.
Ideas:
