i need help changing my o2 sensors!!! rb26
  • i need help changing my o2 sensors!!! rb26
    so i failed air car horribley and i got new o2 sensors. so i found where both of the o2 sensors are but they are such a b**** to get at i am trying to figure out how everyone changes them? special tool or trick? i really need help on this one. also i noticed on the ones i bought from lordco off a 94 nissan maxima the clip is different on one of them. do i just have to splice in the old clip?
    Hi,
    I changed my O2 sensors recently and I know where you are coming from. Get yourself a set of metric "Crows Feet" wrenches. They are similar to open end wrenches but they go onto a rachet wrench. Use in conjunction with extention and you'll be able to switch them out. Best part is, you won't need to remove any intake piping. 5 minutes tops. Hope this helps. Good luck.
    In our journey, we call "LIFE", we move forward from point A to point B. And along the way, we shall cherish the bumps and curves that are thrown at us, especially when we face them in our
    SKYLINE GT-R.
      yeah, those are a bitC* sometimes hey. Its hard to get anything other than a 17mm stubby wrench and all the O2 sockets are for the larger size sensor.
      If their going on the trash just cut the wires off and fit on a 17mm deep socket and there ya go. Or do what was mentioned above. Make sure your new sensors will fir in the bungs before you go ahead with this or your going to run into that problem.
      You cant solder the wires for o2 sensors. They are stainless wires and even with flux, the solder wont run. Just use crimps in this situation. Ghetto looking but better than a crap connection.
      Or try to get a proper O2 that plugs in. I know they are out there, I just forget what car or number they are. Maybe someone here can pop in?
      ALLEN PETERSEN
      Number (604) 961-2449
      RB30`s for sale!
        yeah im looking at doing my sensors as well no luck trying to find an 02 sensors at the local auto supply here in calgary. and been searching for how to DIY.
          i got a pair that i used for air care and thats it. you can buy them off me if you want but they werent cheap
            is it a crossover or an oem?
              crossover. ntks
                I recently bought 2 brand new oem ones. Pm me if you want the part numbers. They will run you just over 300 dollars from the dealership.
                  What I did was make my own 17mm O2 sensor socket. get a 17mm deep socket from canadian tire and cut a channel down the side. works perfect for me.
                    I had to add on 18 inch of wire because the bung on the a/m pipe was further on my lancer. Never had a problem with my weld and O2 working great. Maybe those are different?
                    03 lancer dead
                    68 gmc w/355 cid rice killer
                    05 chevy silverado L33
                    2010 crv Wife's ride
                    1987 Harley Softail custom
                      exactly what i did
                        i had no problem using a 17mm crows foot socket and a few extensions... whats wrong with you people? :S
                          PM Vuk@AMS he might have some, 50$.
                          AMS is Canada's premier tuner and parts developer/provider for Nissan Z vehicles (300ZX, 350Z, 370Z), Infiniti G vehicles (G35, G37), and the Skyline GTR (R32, R33, R34, and R35 GT-R). AMS also specializes in performance tuning and OEM servicing of all Nissan and Infiniti brand vehicles.
                          According to this: http://forums.gtrcanada.com/gt-r-tec...ibility-3.html
                          NTK 24064 also work...and they are also about 50$.
                            I had no problem changing mine. I my custom 17mm shortened wrench. I put a little slit on the box end to fit the wires through. Add a little heat in the right spot and you should have it. Sometimes taking a second to think about it helps too!
                              I found the NTK 24064 ones off ebay and they are as cheap as it gets, Napa sells them for like $100
                              http://www.ebay.ca/itm/NGK-NTK-24064...#ht_500wt_1156
                              worked like a charm for me and they have pretty fast free shipping too
