Hey guys. I'm having a bit of trouble diagnosing source of a coolant leak. Basically, I've had to take off my intake plenum several times now to fix coolant leak issues, it's a real headache. I guess the hoses are so old that they are now deciding to all blow out at the same time! Not to mention the cold weather may have an effect on them.
I've replaced all possible culprit hoses: the 2 small hoses that connect to the metal lines at the back of the block (turbo cooling i suppose), the 2 medium sized hoses for the oil cooler. I havent changed the 2 heater core hoses since i don't have the kit yet, but i dont believe they're leaking. I put everything back together, and some coolant is still dripping from the bellhousing below, and a little steam rising up near the firewall by the clutch cylinder etc... At this point i'm a little confused. Assuming the hoses I changed arent connected badly, what else could be leaking?? Is there a line or 2 i'm not seeing, maybe something running to the tranny? or from the firewall and backward? It's pretty hard to diagnose with that plenum in the way! Maybe i'll grab a mirror.. Any suggestions are appreciated!
