So I am super paranoid about my RB26 oil pressure it being a r32 motor with stock bottom end.
I really dont want to tear into the motor just yet, I would like to replace more than an oil pump/collar to make it worthwhile.
So anyways, I just did an oil change to Castrol Edge 10w-30 oil. We have been getting fairly cold temps here lately (0 degrees celsius) so thats why I choose the 10w30. Normally in the summer I try to run a good 50, or even 60 weight oil, which does seem to up the pressure a bit more. But the manual calls for 30 weight oil, and these are the values I get with a cheap mechanical gauge after a long street drive. (the electric guage shows similar values)
idle (950rpm): 17psi
2000rpm: ~36psi
3000rpm: ~50 psi
4000+rpm: 70 psi+
Now these numbers seem a bit low to me. The motor runs great and doesnt knock or anything, I have been running it like this for about 2 years. I have been avoiding the rev limiter as much as possible and do not spin high RPMS (under 7500rpm)
The GTR manual calls for :
idle: 21psi
2000rpm: 3 bar 45psi
3000rpm: 4.5 bar 60 psi
Should I stop worrying? Should i change to a 50/60 weight asap?
What do you guys usually get for oil pressure numbers (I know a tomei or Jun pump will spit 30 psi at idle, not really interested in aftermarket pump values, just oem values with higher kms motors)
2000rpm: ~36psi
3000rpm: ~50 psi
4000+rpm: 70 psi+
idle: 21psi
