Hello!
I've been trouble shooting my car lately for some cold start problem, and found out that my MAFs are giving me different voltage readings!
For example, with the key on the bottom MAF is gving me 0.25v while the upper MAF will only read 0.18. But at idle the difference will be significant. MAF 1 will be around 1.25v, and MAF 2 around 0.80 only!
Any of you guys know what is the correct MAF voltage values w/ the key on and at idle?
For example, with the key on the bottom MAF is gving me 0.25v while the upper MAF will only read 0.18. But at idle the difference will be significant. MAF 1 will be around 1.25v, and MAF 2 around 0.80 only!Any of you guys know what is the correct MAF voltage values w/ the key on and at idle?
