Hey guys. I started my gtr up this morning. It was about -15, so not even close to the worst i've driven it in. I started reversing and stalled (this multiplate clutch is a bugger). Then she wouldn't start back up!
It has an aftermarket ecu, and I think it dumps a pile of fuel in on cold start, i think maybe even more than stock. So i'm thinking maybe its flooded???
When I got back home I tried starting it with the throttle wide open, closed, and also took out the fuel pump relay and cranked it for a while in each case. The outcome doesnt seem much different regardless of what I do. I can get it to hickup and combust a little, but not enough to start up. I smelled the exhaust a few times after cranking and it smells like gas.
The fuel pump is definately working (can hear it at least), it couldn't be coils as they can't all go at once (although i suspect they are getting old). I'm not sure what to think. Simple case of being flooded? Maybe I need to check the main 75A fuse... This doesn't make tons of sense to me. It should at least idle a bit. I've turned it over so so so many times with the throttle wide open / fuel pump relay out, could it still be flooded?
