I know there are postings on here already regarding this but my situation is apparently different... I think.
Car idles at about 1400RPM, starts perfectly, runs/idles smooth. Pulls great everything works and runs wonderfully except it runs rich.
I've had it to Nissan and we went over the car thoroughly. All sensors are in spec. Tried to adjust the idle both with the NON Consult method and with Consult. No luck.
The computer is trying to lower the idle by lowering the AAC valve to 2%. Should be about 40%. This also "suggests" the AAC valve is functioning properly. AAC valve has been completely disassembled and cleaned.
With the input of two tecks both with over 20 years experience the only thing they suspected is something was done to the ecu forcing the car to idle like that.
Does ANYONE have any suggestions?
I'm trying to make sure everything is working properly on the car before installing my PFC.
Thanks for any input!
