Hello guys,
im fairly new with skylines and just had a couple questions regarding turbo setups and advice to what works and what doesnt. i do have a automotive background but even though vehicles might share the same principles and basic function i do understand that some applications might apply better than others ~differences on how a vehicle reacts to mods.
So here's my situation, since the rb26dett's have stock twins, everything is doubled, maf, chargepipes, plumbing , etc. kind of a pain in the bummmm..
A single setup not only makes plumbing easier it might actually be a little lighter than a tiwn setup and easier to diagnose as far as leaks of isolating a problem in the future.(i know a lot of 2j people that did single setups and been very happy)
BUT.....THERE'S one thing from stopping me..
I DON'T want to run an EM. or i refuse to buy one..
Mainly for one reason, i want to keep the motor setup as stock as possible since i need reliability and longevity.
But since the motor originally was wired/came with 2 mafs, is it possible to run a single without needing an EM? i dont mind not having big power/numbers i just want to eliminate the old and tired stock twins and in the same process have a cleaner/easier to work on engine bay.
to make this happen what do i need to do?
*find out how much max CFM the stock twins on a stock tune/boost can push?
*find a single turbo that has the same CFM output as the stock twins combined?
*keep boost levels relatively conservative, As if the car has stock twins?
would the car act up if i decided to eliminate the other maf? of do i have to run it like so..
Chances are everythings going to be homebrew except a single turbo manifold for the rb26.
***My goal is to run a simple single turbo setup, stock fuel, stock everything, runing pumpgas 93oc. to keep the car reliable and relatively simpler
any info regarding this matter would be greatly appreciated! Gurus/experts/seasoned builders/tuners all welcome.
Thanks for reading!
Thanks for reading!
