**(Disengaged title is wrong)** So I recently swapped engines and I put an Ogura twin plate clutch on my new engine with an OEM throw out bearing. I had an OS giken twinplate on before but it always disengaged really high in the pedal. So now that I know your supposed to use certain sleeves as well as throw out bearings I'm thinking that the sleeve is OEM which is putting pressure on the plate constantly. You can hear the clutch spinning inside the tranny when you start the car in neutral. So should I go ahead and buy the Sleeve and bearing set off of RHDjapan? I'm thinking that this is the only thing that could be causing this... I'll probably have a shop drop the tranny because I am not pulling the engine again.
Clutch always engaged...
