I have a high idle problem I'm trouble shooting. ALL of the usual (and unusual problems have been elimated. There are NO vacuum leaks and everything is functioning normal.
Where I'm at now is...
I have the recirc system disconnected on the filter side.
If I plug where it goes into the intake side AFTER the MAF the idle drops to normal.
I'm trying to determine if the recirc system is functioning properly.
I'm running a PFC and suspecting I may have to play with the MAFs to solve the problem.
Also, when the engine is at idle should the recirc valves be open or closed?
Thanks for any input!
