hey guys I'm about to do my first oil change and i was just wondering if mobile 1 is ok to use or if i should go with royal purple, the car is stock with intakes and turbo back exhaust and is only used on the street, also i read the fluid sticky and i seen one post that said 5.3 ltrs and another with 4.7 ltrs of oil is 5.3 only if you have an oil cooler thanks in advance
oil change
Mobil 1 5w-30 has been fine with me, excellent cold compression, smooth. It's more than 4.7L with a filter change, since I have to buy a 4.7L gal containter with another small quart to fill up (but I fill to the bottom of the hump).Originally posted by bakerman1978 View Posthey guys I'm about to do my first oil change and i was just wondering if mobile 1 is ok to use or if i should go with royal purple, the car is stock with intakes and turbo back exhaust and is only used on the street, also i read the fluid sticky and i seen one post that said 5.3 ltrs and another with 4.7 ltrs of oil is 5.3 only if you have an oil cooler thanks in advance1992 BNR32 SKYLINE GTR
So when I'm doing my oil change if I don't have a aftermarket oil cooler what amount of oil will I need?
And btw I thought there were fluid quantities in the Gtr tech section stickied, what happened to that?Miss driving sooooo bad! Need to get a car on the road ASAP!
I'm bone stock so you can use my quantity as a reference. As for the sticky, I don't recall one on engine oil, specifically. The misc drivetrain fluid sticky is still there though.Originally posted by cschepp View PostSo when I'm doing my oil change if I don't have a aftermarket oil cooler what amount of oil will I need?
And btw I thought there were fluid quantities in the Gtr tech section stickied, what happened to that?1992 BNR32 SKYLINE GTR
Since I work for them, I don't support their **** (mobile)
However I was on amsoil for some time. Good stuff. Recently upgraded to royal purple xrp. I watch alot of speed tv and it seems that's all they use lol. I have a 9L+ capacity but still change oil every 5000km. I run 5 or 10-40 when available. When I was low power/oem I used amsoil 5-40 European turbo car oil. Bout 20,000kmLast edited by Bruizer; 05-29-2011, 12:52 AM.No build thread.
1991 nissan
El terror
