1991 Skyline GTR clutch DIY question
  • 1991 Skyline GTR clutch DIY question
    Anyone know where there is a video on How to change the clutch out on these cars.
    Im able to do the job just need the instructions.
    i dont know of a video but there is a skyline manual which should help you
      if u need instructions...............i dont think u should attempt
      Being built...
        No different than doing a clutch on any other car really. If you havent done one before it would be wise to have a friend help that has.
          What do you néed to know?
          Remove shifter
          Remove starter
          Remove front driveshaft
          Remove rear driveshaft
          Remove and plug hicas line
          Remove crossmember
          Remove bellhousing bolts
          Drop tranny and replace clutch
          Reverse it.
          GTRC-OG
            its also wise to drop the tranny crossmember and let the tranny hang to get the top bell housing bolts and starter. Then just bolt the crossmember back up, remove the rest of the bolts and then you can set the tranny on something with wheels and drop the crossmember again.
            PS you will need lots of long extensions and be very careful torqueing down the pressure plate.
              Thanks, I've done it on a gtst.just wasn't a 100% on the GTR
                +1. I think you can do it cause you can't afford a shop but if you screw up or can't complete it can and will cost more than a shop doing it from scratch.
                No build thread.
                1991 nissan
                El terror
