I wanted to post here to get some helpful advise. Sorry for the long post, just thought i'd gather some thoughts and some ideas:
* Drove home one night and I noticed a weird sputtering sound and loss of power. This was right after i drove through stripped highway in preparation for paving. Because of my suspension (APEXI N1s) the car had loud rumble and vibration.
* The exhaust temp light started flashing and sometimes stayed on for about 30 seconds. At this time the car is in limp mode and i had to drive home.
* So i get home turned off the car and pulled the battery and discharge by pressing on the brakes. I turn the car on again after 20 minutes of the battery being pulled and started the car...still in limp mode.
* The next day I ran the ECU diagnostic codes and found the code to be 12 (MAF sensor circuit) Air Flow Meter. Took off the MAF sensor and gave it a clean (MAF sensor cleaner spray). Popped the MAF sensor back in and the car ran fine after a hard test drive. Parked the car, let the car heat soaked then tried starting again...again the car sputtered and onto the limp mode.
* Onto the next day, found the soldering fix in skyline australia and cracked open the MAF, found the solders are in fact weak where the pins connects, applied good amount of solders. Drove the car again and replicated what I did previously and seems the car is back to normal. (drove hard + park + heat soaked + re-start) Re-sealed the MAF sensor.
* The next night I went to a meet and we did a cruise there (i meant no hard driving, proper shifting, no hard pulls). Parked @ the underground meet and let the car sit for about 2 hrs. On the way home, started the car and I noticed the sputtering sound is back and behold the limp mode was back.
* Another day with the car, checked all the voltages of the MAF sensor and ran trouble shooting the service manual provides (all voltages checked out with the MAF). Ran ECU diagnostic check again, this time code 55 (All OK!) Had my friend come over and plugged in his working MAF and the same limp mode is happening again.
At this time I am looking into checking if there are any vacuum leaks etc. Now any ideas GTRC??? little help pls.
Thank You in advance!
