Who's built motors with big cams in it? I don't mean got them built, I mean actual firsthand knowledge.
Suddenly I feel like there's a million things I've overlooked and I just want to know if anyone has answers before I go doing things the hard way or not ordering parts that I'm going to need.
At what lift does piston to valve clearance start being an issue? I've got wiseco pistons and have probably lopped 20 thou off of the head and block (combined). Using a stock thickness metal head gasket.
Are adjustable cam gears really necessary with aftermarket cams or no? I'm going to about 10mm lift and probably 280* duration. I figure as long a piston to valve clearance isn't an issue I doubt I'll need to do much adjusting, at least not at this point in the game. I don't need to eek every single last horsepower out of the motor.
Those of you that have gone with smaller base circle cams, what did you do for valve clearance? I'm thinking about just getting 2mm and 2.5mm (or whatever I end up needing) thicker shims made. Has anyone else done this? It seems like the easiest solution as I kill two birds with one stone.
Anyone that's running stainless valves and bronze guides, what are you running for stem to guide clearance? Supertech and brian crower are giving me conflicting numbers, if I go by BC's numbers the bronze guides I bought are too big inside and I'll have to get inserts made, which irks me because these parts are all brand new.
Is 2.5 thou too much clearance for a stainless exhaust valve? What about 3? It seems like a ton compared to domestic stuff but not that much more than what the factory manual says. Supertech guy wasn't too sure but felt that 3 thou was fine and any less than two was not.
PS: any useless replies like "ask your builder" don't help me. I'm the builder, and none of the part manufacturers seem to be able to give me answers, or at least answers that make sense.
PPS: Thought it might be useful if I added what parts I'm trying to use.
Brian crower +1mm valves, BC springs, BC titanium retainers, supertech bronze guides (hate stock valve guides!) and reground cams with either a 2mm (intake) or 2.4mm (exhaust) smaller base circle.
