so pretty much i wanna know if i need 2 or one bov for my r32 gtr ive heard 2 because the 2 turbos but also have heard you can use one? is there anything bad or what are the negatives and possitives of using one or 2?
r32 gtr bov question
You can use one, but depending on your setup, you will have to block off where your original BOV's were. Of course, you can also use two, but that generally is reserved for cars that are being run with a LOT of boost and need to release the excess pressure rapidly.Originally posted by 91BNR32GTR View Postso pretty much i wanna know if i need 2 or one bov for my r32 gtr ive heard 2 because the 2 turbos but also have heard you can use one? is there anything bad or what are the negatives and possitives of using one or 2?
Take a look at what other setups are on this site. There is a ton of good info. I personally have converted to single turbo and only use one - it's all I need. Good luck.
Like 272 said.....really depends on your set up and if you are basically stock then there is no point to upgrading the stock setup unless you are looking just for the sound of it. The stock bovs can handle a decent amount of hp (around 400hp? correct me if im wrong)They are few inovators, but many followers....
ya i just want the sound and eventually i will b getting a brand new set up next spring about 400HP ill b pushing so mays well get bovs at a good deal while i can lolOriginally posted by jdm_fantasy View PostLike 272 said.....really depends on your set up and if you are basically stock then there is no point to upgrading the stock setup unless you are looking just for the sound of it. The stock bovs can handle a decent amount of hp (around 400hp? correct me if im wrong)(0=0)_____(0=0)
1991 BNR32GTR
