boost issue
  • boost issue
    so i removed the boost restrictor and it works awesome but sometimes i lose the extra boost and it goes back to stock, go i pull over idle then turn off the car and turn it back on and it goes back to .9 bars does anyone know why this wouldl b acting up?
    (0=0)_____(0=0)
    1991 BNR32GTR
    How many miles on your car? Could be weak actuators.
    03 lancer dead
    68 gmc w/355 cid rice killer
    05 chevy silverado L33
    2010 crv Wife's ride
    1987 Harley Softail custom
      it has 124,000.
      (0=0)_____(0=0)
      1991 BNR32GTR
        let me know what you find out, mine does the same thing....usually sits at around .7-.8 now and sometimes hits .9
        They are few inovators, but many followers....
          I think frankiman had the same problem and he has a bit more KM's on his. He bought some garret replacements... Good luck
          03 lancer dead
            I have the same issue. It almost sounds like a wastegate is being forced open, I can hear the exhaust note get louder each time it does it. Usually coming on the boost slowly in 5th does it for me. Maybe the wastegate actuator spring getting weak and the added exhaust pressure is overcoming it??
              that sounds like its something possible. but have u guys ever lost boost? like i usually hit .9 but sometimes it hits it and then drops to stock (.7) and to get 9 back i gotta shut the car off. im thinking bad idea to take restrictor out haha.
              (0=0)_____(0=0)
              1991 BNR32GTR
                Ive had it hit .9 and then trails off back down to .7.....sounds like wastegate is the consensus lol taking out the restrictor isnt the worst idea, ppl will all have their own opinions on removing it but all in all be happy! you didnt blow a turbo!
                  It sounds like your car was knocking so the ECU reset to safe boost.
                    ^^ That's what I was thinking.
                      hmmm knocking im gonna throw my powerfc back in and see what the sensor is reading.....
                        how would u fix that?
                        (0=0)_____(0=0)
                        1991 BNR32GTR
                          check your base timing and use better gas.
                          if that fixes the problem it was knock.
                          and/or you could use a consult to actively monitor the knock sensors.
                            what is knocking?
                            would u say it b best to put the stock restrictor back in?
                            (0=0)_____(0=0)
                            1991 BNR32GTR
                              It is definately not knocking on my car, if you are getting popping and knocking feel, check your plugs and coils first before you go off the deep end thinking your car is blowing up. These things tend to run rich even with the restrictor removed and they can foul plugs rather quickly. I can almost guarantee the wasetgates or actuators are worn out on these 20 year old cars. If you don't know what knocking is you should do some research you don't have to hear or feel knock for it to be there. Get yourself a wideband o2 sensor or an EGT sensor for piece of mind or spend $100 bucks and get the car dyno tuned, trust me it can be money well spent.
