Floored my clutch - could it be the master or the clutch itself?
    i saw two 12mm nuts like these (without the red) holding the back of the clutch bracket to the car, i faught with the broken side all morning until i got a 12mm with a swivel and rachet on it and was able to take em off.. now i can feel the back is definitely loose, but when I tug the entire pedal still moves with it so I'm sure it's still got one if not a few more holding it to the pedal.. you recall where all the nuts n bolts you took off were? I been fighting with that peice of **** all morning and its frustrating as hell especially since I can barely see a thing
    | O - O ) S K Y L I N E ( O - O |
    I used to do drugs, I still do but I used to too.
      Did you remove the pin connecting the master cylinder push rod to the pedal? Theres only 3 bolts holding it on. 2 in the engine bay on the firewall that hold the master cylinder to the pedal and one under the dash at the top of the bracket.
      I canz take this corner at 195k cause i gots AWDZ. Get real.
