help with external fuel pump
    Switch is good secuirty measure, get out, flip the switch and car will not start. Just make sure its not anywhere near a place where it can accidentaly be flipped.
      yea thats what im worried about accidentaly flipping it while driving.....
        Don't have one for this reason. If a thief wants your car bad enough, he's going to take it.
          8 gauge wire? holy shietz, that size is good for 45amps @115 volts haha
          You're wasting money and weight with that wire size friend.
          Ga 110V 12V
          22 5A 5A
          20 7.5A 8A
          18 10A 10A
          16 13A 20A
          14 17A 40A
          12 23A 60A
          10 33A 100A
          8 46A 150A
          No build thread.
          1991 nissan
          El terror
            haha dont worry bruizer i went with 10gauge wire. all in all at lordco i got 50 feet of 10 gauge wire, a inline fuse holder, 3 30amp fuses, a 30 amp relay, terminal connectors, and relay connectors for 40 bucks tax in. i wired up everything today except for the acc wire. im not sure what fuse i want to run it to tho. any ideas? ignition? fuel pump ?
              can't wait to see the pics!
                not sure which is the acc wire though
                  never mind
                  You can't fix stupid.
                    hozer im taking about number 87. i have to tie the relay into something like kthe fuel pump fuse or the igntion fuse. and speeddm never heard of diy? its a learning process. im not ghetto wiring this up and firing it up. im working on it at my mechanics shop. he is soddering all the wires and double checking everything. thanks for the vote of confidence
                      Ahh kk, tie it into an acc power line (lights, 12v, fan...) Anything that kicks in when you turn the key to the acc position, which includes the original fuel pump fuse.
                        gtrjon thats great. My reply was based on reading your questions. not on assuming that your mechanic friend is going to check it over for you. It didn't seem like you were getting it. Sorry wasn't trying to be a ****. I was trying to make sure your car doesn't go up in flames. If you want to simplify it and run less wiring overall run you relay negative switched.
                          Was going to pm you, but hozer pretty much answered it.
                          14 VW Jetta TDI
                          95 240sx (RB25DET powered)
                          95 240sx ( powered)
                          89 GTR - Money Pit -
                            Nice copy/past diagram for the relay haha. And the way it's says "MUST be wired" is not true. You can wire that up differently to do different tricks
                            No build thread.
                            1991 nissan
                            El terror
                            • #29
                              thanks for all the help guys the wiring is now complete! well see if it works when i start the car this weekend :P
