Well i have a drumming sound thats starting to get a bit loud when i drive the GTR . Its very similar to a noise that i had from 35 inch tires on a 4x4 truck . I'm using dunlop direzza tires and would like to know how noisy these are on the road from anyone else that has had them ?
If its not the tires , i have replaced all diff , tranny , transfer case fluids and that didnt make a difference , I do have a weak 4th gear syncho but that does not equate to this noise .
The pitch of the noise is vehicle speed related , it seems to get a bit louder when i hit the brakes OR undulations in the road force the front suspesion to be under a bit more load, can feel it through the steering column when braking.
It's neither worse nor better on cornering ( so i dont think it's wheel bearings ). The oil drained ffrom the diff was clear and very minimal debris on the magnetic drain plugs (just a slight amount of grey sludge which is expected)
Oil drained from the tranny was the same , very clear , no metallic parts.
The noise level does not change under deceleration or acceleration.
Wondering if its the gearbox main input bearings , or maybe the front diff drive shaft bearings.
opinions ?
opinions ?
