I have been haveing all sorts of rough running and idle issues and one thing I want to check is this screw. It is adjusted all the way down on my motor and the manual says never to adjust it, I just want to make sure it is actually in the right position before I adjust the linkage. Basically I can unplug my AAC and the idle doesn't even change at all, I have removed, cleaned and checked the AAC by applying power and ground the solinoid works fine.
I beleive the throttle plates may be open alittle to much on idle because even with closing the AAC all the way it sits at 1080rpm.
Here is where my screw is,
Any help is appreciated
