So i start my car up last night, And put it in to gear, and notice what sounds like gears in the transfer case as the vehicle is moving. I just finished reinstalling the tranny after a clutch change, and have dumped 2 liters of Nissan ATF D into the transfer case, and reinstalled everything correctly around the shifter, atleast as far as i can remember i did. The shifter boot was torn ever so slightly when the shifter went back in, but it didnt seem bad
Curious if dumping the fluid down the shifter hole is bad practice? is there some sort of bleeding that needs to be done on the transfer case, or should i just recheck my transfer fluid level from the fill whole?
Any help would be appreciated, Thanks!
