The issue I am having is my idle like many other have had from research. However, I have been through the Service Manual and I am still at a loss.
Here is the issue
My idle after many adjustments and checks sits at the 1080 area if I disconnect or connect the AAC makes no difference at all.
-I have adjusted the AAC idle screw to no change at all
-Checked the connector wires for correct voltage and resistance to find no issue
-Removed the AAC, cleaned it, checked that the solinoid works by giving power and ground, and re-installed it with a new gasket, with no change.
-Adjusted my throttle plates to ensure they are in the proper closed position
-Checked the TPS for proper voltage
-Checked and re-timed to 20*
-Sprayed with Throttle Body Cleaner to check for leaks (nothing)
-I have Nistune and have run an active test on the AAC and still no change and reads 2% always because it is idleing so high with out the AAC being used it just stays there at 2%
-Car does run Rich (13 at times turing idle) so my guess is that the ECU is actually seeing extra air from somewhere
-Checked for boost leaks and no issues and boosts fine at 14.5psi
My next guess would be to attack the Air Regulator, thinking it may be stuck. I am a BMW Technician so I'm not some backyard mechanic and this is driving me nuts.
Anyone have any other ideas or agree I should just check out the Air Reg?
Here is the issue
