hi, i just recently bought an r34 engine for my r32 gtr, but theres a couple things that concern me about the swap. the CAS is different, do i install the r32 one? do i have to put the r32 front diff? r34's dont have ignitors, so im gonna have to install mine with my coils? wat kind of wiring will i need to do? will my tomei poncams i have in my basement for my r32 fit? im sure people have done this before, any info would be great, thx
R34 engine swap
I would use a r34 wiring harness, the front diff you will probably want to keep unless you don't have the getrag trans then then I would change the rear diff and driveshaft. And te 32 cams will not work with the r34, sell it and build around it. Put the cam money towards a set of new turboes or something like that. There is a fair amount of mods needed to be done. Check out the build thread section, someone's doing it right nowMiss driving sooooo bad! Need to get a car on the road ASAP!
If i can use my r32 cas, with my r32 tomei cams, with my r32 sard injectors, i would prefer that to keep the r34 head then rewire everything to use the r34 harness. And the front diff i beleive has different ratios then the r32 ( not sure) and if thats the case, i think i have to swap them not to damage the transfer caseLast edited by allwheeldrifter; 10-19-2011, 02:32 PM.Being built...
In your case, just use the r34 engine as long block, swap in your Tomei R32 CAMS, R32 CAM sensor, R32 Oil Pan, Front Diff and use all R32 electronics. People buy R34 NUR long blocks all the time for their R32s.
Originally posted by allwheeldrifter View PostI was thinking if i put the r32 cas, r32 cams (i have tomei poncams), injectors, on the r34 head, ill be able to keep my r32 ecu and harness. Wouldnt it be alot less hassle to do that? Anyways i dont have then r34 ecu and r34 is obd2...
Don't cheap out man seriously grab the r34 wiring harness and ecu! Sell the cams and if your that set on cams which once you hear the r34 you'll be fine with the way it sounds then that money can go towards doing it properly.
A good reason to keep the r34 cams and cas is because of the better flow and ultimately the great sound of the motor. But also look at it from this angle... If I come to buy your car and you say there is a 34 Gtr motor in there, what is one way to tell the difference, cas. There are not many other things that you can tell the difference with. The parts are readily available to do it right so don't hesitate. It's only a few more dollars off the buildMiss driving sooooo bad! Need to get a car on the road ASAP!
I can't really get your point of asking him to sell his Tomei CAMS and keep the stock R34 CAMs. So, you do not think the Tomei R32 Poncam is going to smoke the stock R34 CAM and sounds even better?
Furthermore, he does not need to spend a dime (if he can handle wrenches himself) to swap in the R34 engine if he uses existing R32 harness, sensors, ECU, pans, diff and tomei cams, while having the option of doing all those fancy (may not even be better )things at later time. I do not consider doing things this way is cheap, but a wise and money well saved way to build his GTR reliably.
That's just my 2 cent.
Originally posted by cschepp View PostDon't cheap out man seriously grab the r34 wiring harness and ecu! Sell the cams and if your that set on cams which once you hear the r34 you'll be fine with the way it sounds then that money can go towards doing it properly.
A good reason to keep the r34 cams and cas is because of the better flow and ultimately the great sound of the motor. But also look at it from this angle... If I come to buy your car and you say there is a 34 Gtr motor in there, what is one way to tell the difference, cas. There are not many other things that you can tell the difference with. The parts are readily available to do it right so don't hesitate. It's only a few more dollars off the buildLast edited by xcye; 10-20-2011, 04:40 PM.
^ Fully agree xcye! Get it in and running on the R32 electronics and cams. Enjoy driving it and save up for the R34 (or upgrade) ecu, Poncams, and whatever else is needed and swap over later.Originally posted by SnowSure a condom holds water but you don't see me drinking from one.
i am for sure gonna use the r32 harness and ecu, the only thing at this point that im not sure about is the cas. can the r34 cas be used with the r32 ecu with a bit of wiring? if so...... is it even worth it? because if the r34 cas is "better" then the r32, i might just leave it and get another set of cams for R34 and sell my r32 poncams...?
ps. if anyone is interested "later this winter" im gonna have my mint condition, low milage (65,000km) R32 rb26 for sale with r34 turbos..... but its probly gonna have an r34 oil pan........Last edited by allwheeldrifter; 10-27-2011, 01:31 PM.Being built...
i lived in mtl and i am running a r34 engine in my r32 and i did swap the cas to the r32 ecu a r34 wont work in a r32 anyway the all have the NATS system and to run an r34 ecu you need the # match engine,ecu,immu and the key wich you probably dont so rewire the cas to the r32 ecu. keep the r34 coils pack and rewire the transistor, is like 5 or 6 pins in the r32 ecu that you need to change dont remember wich. your r34 front diff need to be change for an r32 one exept if u use the r34 rear diff. not the same ratio... exept that its an easy swap good luck
