Highest rpm for the RB26 block?
This topic is closed.
  • Highest rpm for the RB26 block?
    Hello,
    I'm new to the forum and NOT a troll! I used the search function and can't seem to find any posts or talk about how high you can rev these motors. I googled a bit and see cranks and components made to rev to 10k but, does anyone do it? Is there anyone that knows of a 12k RB26 bottom end?
    If there are motors out there that rev this high, What I'm really looking for is to find out is, what type or brand of main bearings they use??
    thanks,
    D
    i doubt you will find anyone on here that revs past 9k. barley anyone raps past 8k. i have a fully built bottom end and my tuner was not comfortable reving past 8k. do you really need to hit 12k?
      Here is the thing, I am building a non Nissan motor but, very interested in the RB's design and capabilities. The motor I am building uses a crankshaft that is roughly the same length, weight(actually much lighter in race trim) and handles the same amount of hp. It handles the same displacement but, is only a 4 cylinder vrs 6 cylinder.
      All that being said, I am looking to maybe use the RB26's main bearings, journal/block design, etc.. Maybe not all of it but a good portion of the design. The only thing I am unsure of is if it can handle high rpms.
      For example, If someone here said yes, people use "xyx" brand bearings and rev to 12k all the time, I would continue to go down that path. Seems the Honda's and Mitsu's can rev very high with whatever brand bearing they can find. I considered those designs too but, again, their over all designs are much different that of the RB or my motor.
        I took my stock RB26 past 10,000rpm. Hell yeah.
        GTRC-OG
          ^ maybe that's why it blew up.... Just sayin
            Actually I figured out that was NOT the reason. The knock came from oil deprivation...from an oil tube being loose. I really don't think it was the high rpm. Obviously that didn't help though.
            GTRC-OG
              Lol, ya that can't be a good thing to take the engine past that rpm but with rb engines I wouldn't trust it! Oil starvation is number one problem with them
                Is it the delica/starion engine? xD
                Double track drift, yo.
                (oo sκylιnε oo)
                  From what I can remember, they reved to 11600rpm? in Australia with this car -
                  Search using "Exvitermini" (used to be the name of their website that had specs of engine before it was shutdown).
                  Also I think Apexi with their RB26 powered R33GTR dragcar reved to 11000rpm.
                  This person is a knowledgeable RB person in USA and I think used to work for Apexi USA, XS Engineering -
                  With high reving EVO or RB type engines, this place in Australia can make for you the reinforced block with better cradle design you need and probably answer your bearing questions -
                  With stock RB block you can make a stronger custom cradle design for higher hp, rpm applications -
                  Race bearings used on some RB engines are made by ACL -
                  ACL,performance,bearings,motorsport,engine parts,engine bearings,race series,main bearing,race bearing,con rod bearing
                  Nismo bearings have a coating that helps with longevity of bearing -
                  We design, manufacture, and sell automotive parts, as well as providing vehicle set up services, based on the technology, passion and spirit cultivated in the motorsports field as the Nissan works team.
                  This can be done by Calico Coatings -
                  Calico's PECVD, DLC, PVD, TiN, ceramic, Teflon, and thermal coatings reduce friction, wear, and heat. Calico also offers non-stick dry film lubricants, break-in lubricants, and more to extend the life of moving parts.
                    Skym, thank you for all the links! I have been looking around for the last few days and kinda came up with what you are all kinda saying here. I love the RB design and for sure it can make big power but, doesn't seem that it likes to rev easy.
                    I am going to contact ACL and talk to them about the bearings. Like I said, I am building another motor but, it will be similar to the RB minus two cylinders. The rod ratio is great and it will rev so, I need some bearings to match. I also looked into Honda stuff but, they have very short cranks that won't flex as much as a longer one so, Honda is out.
                    I will let you all know as things progress. Where is a good place to pick up a bare block/girdle in the States? What do they cost?
                      Impressive , i know this is an old thread but just wanted to share my thoughts !
                      Last edited by cortexx; 09-02-2013, 09:42 PM. Reason: edited to reduce chance of flames
                        Originally posted by christdeyoung View Post
                        Are you serious?
                        Ah yes this is a 13 month old thread
                        Last edited by cortexx; 09-02-2013, 09:44 PM. Reason: reply truncated and manners added !
                          Yes - still 10,000 rpm is still impressive no matter how long ago it happened and how long it took me to find this thread
                          Last edited by cortexx; 09-02-2013, 09:46 PM. Reason: another light hearted attempt at civility
                            10,000 rpm is a very escalated level to rev the rb26 .
                            Last edited by cortexx; 09-02-2013, 09:48 PM. Reason: a change of direction to better fit the much nicer atmosphere in this thread
                              Usually i get a little angry with people , but you guys have been so nice i'm feeling very serene and calm even though this thread is a little old
                              Last edited by cortexx; 09-02-2013, 09:50 PM. Reason: He isnt really angry because the flames never happened !
