Hey guys, I have a R32 GTR and I'm having issues with the steering. For some reason the steering wheel turns really easy some times, and there's other times its stiff as hell to steer. Any ideas on what the issue could be? I've checked the lines and there's no leaks, the fluid is full, and I've replaced the power steering pump and it still hasn't solved my problem.
BNR32 GTR Having issues with steering stiffening
aftermarket steering wheel? if it does make sure the hub that is installed is the proper one for the car with the steering sensor in it. if it doesnt this screws with your hicas and speed sensitive steering and can make the steering stiff etc. also check your fuses1992 Nissan Skyline GTR
2003 GMC Sierra SLT
1972 Datsun 510
Did you check your steering shaft's U joints? My Sentra had the same issue which I let worsen until the steering started locking up while turning...Originally posted by dak24 View PostHey guys, I have a R32 GTR and I'm having issues with the steering. For some reason the steering wheel turns really easy some times, and there's other times its stiff as hell to steer. Any ideas on what the issue could be? I've checked the lines and there's no leaks, the fluid is full, and I've replaced the power steering pump and it still hasn't solved my problem.1992 BNR32 SKYLINE GTR
there is the speed sensitive steering sensor in the steering wheel hub. which skyline is this because i dont think you live far from me. ive probably seen it. you can pm me if ya like. i just live in waverley but work in dartmouth1992 Nissan Skyline GTR
2003 GMC Sierra SLT
1972 Datsun 510
HICAS ECU looks at speed via dash (speedo cable), steering angle sensor behind steering wheel. I think is also connected to divertor in engine bay (next to battery) and to divertor near rear wheel on drivers side which if faulty could cause HICAS light to light up on dash.
Also HICAS light on dash can light up if powersteering fluid level is low in powersteering resouvoir in engine bay. It should happen when cornering, where fluid moves to one side of resouvoir.
HICAS ECU controls a solenoid on front steering rack that controls steering weight when car speed increases.
Here's how electric powersteering works and how to play with the weight of steering -
The ECU mentioned in link above is the HICAS ECU on Skylines.
When HICAS ECU failed on my car due to leak in rear bootlid, it allowed water to drop onto HICAS ECU which entered breather holes (water marks on top of HICAS ECU) and damaged the HICAS ECU circuit board. The result was that steering was heavy. Also had bad solders just like MAF, etc. Replaced HICAS ECU and turned upside down so breather holes face downwards, problem solved.
Also GTR HICAS ECU is different with I think programming to GTS HICAS ECU, so if have to replace ECU, look at part numbers and select correct HICAS ECU.Last edited by Skym; 01-02-2012, 10:11 AM.RESPONSE MONSTER
