Dakota I am in Calgary. And thanks for all the help!!!
Something bad happened!!
Hey guys so got my car on a lift today and there is no holes and not very much fluid sprayed around either the only thing I could see without ripping everything apart is that the fluid that did come out was right where the driveshaft goes into the diff.
and I can't figure out how to upload pictures from my phone._____GT-R_____
_____GT-R_____
My Picture Album Link
copy & paste this ☞ > > http://smg.photobucket.com/albums/v201/74260zt/rb26powered74zcar/?start=all
if there is grinding then its internal damage....in ur diff housing u have the ring gear, pinion gear, spider gears, side bearings and caps and bearing for pinion....hard to say what got damaged w/o doing an open heart surgery....if ur familiar with mechanics then u will know what got damaged and u need to replace parts as necessary...also u have to set the backlash, coast/drive and bearing load, if i were u id buy a used diff complete and change the fluid saves time and money....
DD: R50
Sorry, I missed the part about it making a grinding sound when I posted my above post with the Diff picture...Originally posted by Alberta92 View PostAnd also i tried the 4wd fuse and still does a grind almost as soon as i start to move like within 5ft!
