I'm just saying, why go any further if your not making any more power after that? Unless the engine is tuned to keep producing more power after that, I just see it as causing stress. I will admit, I'm terrified of blowing the bottom as it sits since it's still stock. So until it's upgraded I'm fine with the 7k I limit my self too.
Yes, the usual causes of failure would be from over revving. Too fix this you need a 93 and up crankshaft, or you can go another route and have a wider collar put on the current crankshaft. There are other helpful ways to help your engine breath better and not blow from oil starvation that you should look up when you have time.
