Greetings from USA.
I recently took ownership of this R32 GTR. I don't know much about this car since there are not many here. The 4wd light stays on but the ABS and Hicas goes off normally after engine start.
After some search here is what I have done:
Checked under hood and dash fuses all good
Checked the LED error and flashing code 21.
Checked the TPS(I see last owner installed a new unit)
Checked the TPS voltage using a scanner and shows .4v throttle closed.
Checked the fluid level in trunk. (right between min and max)
Turned the ignition on but only heard fuel pump sound. I don't hear the 4wd pump going or the fluid moving or going down.
I printed out R32 manual and followed diag for code 21. Measured voltage at 4WD ECU pin 47 and 48. Found .4V at connector. Flow charts says to replaced 4WD ECU. Makes sense since the voltage signal is getting to the 4WD ECU but the ecu still flashes this problem then ECU defective.
I replaced the ECU and still same code 21 and 4wd light on.
Well what now?? I am thinking to jump the plug and see if the 4wd pumps works or run two new wires from ECU to 4WD ECU for the TPS signal?
Any ideas?? thanks.
Any ideas?? thanks.
