I've had this real annoying rough idle/misfire forever now and do my usual hours of searching this site and others for possible causes but nothing has solved my problem. I just read today that if I unplug both maf's with the key off, start the car and it runs than I have a maf sensor problem. Is this true because I did this and it runs and idles but won't rev past 3000rpm which you would expect with them unplugged.
I have cleaned both mafs before, replaced plugs, replaced coils, set tps, swapped out fuel injectors, checked codes, etc. It builds all kinds of boost and does not hesitate, stumble, stall anything while I'm driving, just at idle it's rough like a v8 with a giant cam or something, it even sounds like it at idle, lumpy like.
Here are a few videos of my problem.
