What could be the issue ( vid inside )
  • What could be the issue ( vid inside )
    I've been trying to solve this problem for a while
    Possible problems I have eliminated
    checked both mafs
    all injectors are functioning properly
    new spark plugs
    eliminated 6 vac leaks by pressurizing the whole intake and ic there is no more vac leaks
    fpr is good
    TPS was replaced with one that was functioning 100%
    IAC was properly cleaned out and functions properly
    Ecu is also not flashing any codes
    I might have forgotten something If I remember I will add it to the list
    Here is the video, idle was a little high just to make sure it didn't die and still did once.
    the AFR was a little on the lean side in the video but it goes to 10.0 alot, it runs rich and I can pull a strong 20 vac even if the gauge was showing 18-19, it was due to the higher idle in the video
    click on the picture to show the video
    A private space for your group's photos and videos. Share, react, and relive moments together. Available on iOS, Android, and desktop. Free for new sign-ups.
