Battery wire split
  • Battery wire split
    Battery cable split
    My car wouldn't start the other day so I checked the engine bay and saw that the battery cable split in 2 basically. Heres a pic of it after I unplugged the cable ImageShack® - Online Photo and Video Hosting
    Anyone know where I can get it replaced or repaired? I don't know if the plugs are universal or are they nissan/skyline specific.
    Thanks in advance
    You can do it yourself, lordco will have the battery wire
    TOP SECRET- 85%
    91 accord exr - DD
    R32 GTR - summer car SOLD
    R33 GTST (sold)
    91 civic hb (swap motor) - sold
      Problem is I cant get the wire out of the housing. Only the back end opens up but the wire wont come out of the plastic plug.
        pic doesn't work
          By laaay_z at 2012-04-22
          sorry about that. should work now
            When looking at the plug from non-wire side you'll notice a recess. Use a small, flat precision screwdriver to lift the clip inside releasing the spade terminal.
            The wire is crimped and soldered and will be a pain in the a** to repair.
            Originally posted by Snow
            Sure a condom holds water but you don't see me drinking from one.
              alright, thanks for the tip !
                Thought I'd throw this up here for peoples
                Link-Fusible 24022-F6100 about $25 after taxes from Nissan and common with older domestics so readily available.
