Okay im just going to go ahead and start a tech thread so its not over looked by anyone.
I originally made this thread because i was searching for knock sensors or cross reference #'s, but now im going to post as tech in case anyone else has some good info i could use!
OLD THREAD > http://forums.gtrcanada.com/gt-r-tec...ref-knock.html
Last post in old thread :
Yeah today i got a few 80+ and even a 120!!
However my head is slightly built and I've got so much noise coming from it!
Cams, port, manifold port, (& possible springs, not 100%)
My last head was pretty noisy too after I installed pon cams so I'm wondering if maybe I'm picking up knock from the loud a$$ head. Maybe re-shimming the cams might quiet her down.
Weird thing is though, when I went to Tommy, my ign timing was set at 20° retarded, and we could only set to 17° advanced before we maxed out the cas adjustment (all the way right). So maybe its true knock? When we were tuning there was no det sound at all until we upped boost to 17. No hiccups or anything. To be safe he backed off the timing even more after the tune so there shouldn't be any room for error.
During the engine break in When my timing was at 20° retarded and my wastegates unhooked, I didn't register any knock over 30(0 boost) from the few times I checked. So this is why I'm worried because now when its advanced to 17° its showing crazy high knock.
This also makes me think my knock sensors are still functional. Unless they're over sensitive or loose, and now any tiny knock is being shown as a really big knock?
Bear in mind this is an entirely different block, knock sensors and power fc from the block/sensors/pfc I had before. My last build never knocked over 50 on that power fc.
I don't know....
< Posted by me.
I don't want to eat my new engine, and even though my tuner says hes confident its safe, the little blinking red light on my dash scares the hell outa me! Invested far too much to rebuild again...
FYI if it helps, I can register a knock of 60 (power fc) just from revving the engine in neutral....
Also, This engine was built as "Loose Clearance", meant to spin fast and high.
407WHP @ 15.5 PSI < Racing Greeds Dyno.
I don't know....
< Posted by me.
